robert0762 Posted January 8, 2010 Report Posted January 8, 2010 I know this means it will be slightly more gas per volume then 32:1 but is it enough to make a change in jets that I am running? Quote
GrMeyer Posted January 8, 2010 Report Posted January 8, 2010 It did to me. But it also go colder. Quote
volcrano Posted January 9, 2010 Report Posted January 9, 2010 I know this means it will be slightly more gas per volume then 32:1 but is it enough to make a change in jets that I am running? running less oil which u are with the 40:1 will richen your air/fuel ratio slightly,wont be enough to make u worry.it cant hurt in these temps as its colder but when you do run less oil,there is a little less lubrication.use a good oil for ur mix-i like klotz supertechniplate esp. if u are running less oil.u would be wise to put bigger jets in and if u havent done that for the temp. change for winter,just changing the oil ratio to gas is not going to be enough to keep piece of mind.its a coin flip of running lean.hopefully u richened mains bro-i see ur in MD. Quote
AKheathen Posted January 13, 2010 Report Posted January 13, 2010 it slightly changes the viscosity and atomization. just go through checking the mins and readjust the airscrews after the switch Quote
