Does anyone have pics of the top of their case/motor so I can see how the vent lines are ran and all other cables for a rebuild I’m doing?
The vent line on the clutch cover and the rear of the case both tie into the "T" fitting then run the hose up higher than the motor so the oil doesnt come out. For the cables run them under your tank and there is a small metal flange that run right in the middle of the tank. Put your cables through there. Everything else you can just tie up out of the way with zip ties.
There is no one way that you have to route it all. As long as you dot route it so the wires/cables are so tight they barley fit your fine.
Edited by Bansh-eman
