majorcr3 Posted December 22, 2009 Report Posted December 22, 2009 I have a bottom end out of a 2006 banshee. I have 2 other motors that are projects so i dont want to put any money into this one. Asking $350 shipped. The motor comes with: Both cases in great shape - just needs cleaned stock crank - needs rebuilt drive gear and water pump gear on the end of the crank tranny is good shift drum and rocker arms in good shape clutch outer case cover in good shape water pump clutch basket clutch pressure plate kicker spindal and gears idler gear clutch plates mulitiple nuts and bolts ect DOES NOT COME WITH: stator clutch inner hub inner shift shaft nuts for both ends of the crank keyway for the clutch side of crank needs some random nuts and bolts I priced it out that i would take about $150 to make it a solid complete bottom end. Most people on here have most of the parts just lying around anyway. Just looking for some money to put into my other project. My ebay mane is majorcr3 if you want to look at some feedback. Quote
