ManeOne Posted December 20, 2009 Report Posted December 20, 2009 I don't understand why my '00 Banshee gives me this problem. When I start it, the left exhaust seems to not be throwing the same amount of pressure than the right one. And when I run my Banshee, I rev it and it doesn't respond good until I have pushed the accelerator almost all in. If anyone thinks they know what is wrong can you please post it. Thanks. Quote
GNR101 Posted December 20, 2009 Report Posted December 20, 2009 I don't understand why my '00 Banshee gives me this problem. When I start it, the left exhaust seems to not be throwing the same amount of pressure than the right one. And when I run my Banshee, I rev it and it doesn't respond good until I have pushed the accelerator almost all in. If anyone thinks they know what is wrong can you please post it. Thanks. blocked pilot jets carbs not in sync Quote
LiftdT4R Posted December 20, 2009 Report Posted December 20, 2009 blocked pilot jets carbs not in sync Definately. Sounds like a carb issue, you may want to post your mods, and current jetting setup in the jetting forum and see if you can get her dialed in close. You should also check the compression on the cylinders, it could be time for a rebuild. While your at it make sure the reeds look fresh, broken reeds make it run shitty too. Quote
AKheathen Posted December 21, 2009 Report Posted December 21, 2009 x3...clean your carbs, do some research in the jetting section and you will see all tat effects your jetting, and what jetting effects........cleaning the carbs is an important part of routine mainenance, too. Quote
