beauseafus Posted December 15, 2009 Report Posted December 15, 2009 please give me wisdom, i installed a motion pro twist throttle kit, with idle adjustment screws, on my 2000 banshee, i eliminated the t.o.r.s system completely, now it is consuming fuel 3 times as fast, some how it is running rich as hell, loading up , and running ratty bottom to mid range, runs great on the top end full throttle, all i really fooled with is the idle speed, i dont understand what i did wrong, advice would be much appreciated! Quote
bansheeseat$$ Posted December 15, 2009 Report Posted December 15, 2009 Make sure you put the cross over tube between the carbs back in and also make sure you put the slides in correctly and in the corect carbs. Quote
wacko2000 Posted December 15, 2009 Report Posted December 15, 2009 You went wrong when you installed the twist throttle. Those things are fricken crazy on a banshee/quad Ive seen so many people wipe out running twist throttles Anyways, goodluck and i hope you get your problem sorted out Quote
AKheathen Posted December 15, 2009 Report Posted December 15, 2009 Make sure you put the cross over tube between the carbs back in and also make sure you put the slides in correctly and in the corect carbs. x2...there is something you did or forgot durring r&r that is the issue. check these things first Quote
Paul M Posted December 16, 2009 Report Posted December 16, 2009 You went wrong when you installed the twist throttle. Those things are fricken crazy on a banshee/quad Ive seen so many people wipe out running twist throttles Anyways, goodluck and i hope you get your problem sorted out [/quote you got that right ! Quote
shanYE west Posted December 16, 2009 Report Posted December 16, 2009 Give the carbs a good cleaning.. Make sure no aluminum shavings found there way into the needle and seat. Quote
