quikshee Posted December 2, 2009 Report Posted December 2, 2009 Picked up an extra set of 450 shocks and need to have them gone quick, the guy I bought them from said they needed a recharge. They don't leak and aren't bent in any way. They look to be in really good shape other than some chipping on the paint.. 165 shipped plus paypal fees Quote
cousinsracing Posted December 2, 2009 Report Posted December 2, 2009 Picked up an extra set of 450 shocks and need to have them gone quick, the guy I bought them from said they needed a recharge. They don't leak and aren't bent in any way. They look to be in really good shape other than some chipping on the paint.. 165 shipped plus paypal fees what all do you have to do to recharge them? Quote
quikshee Posted December 2, 2009 Author Report Posted December 2, 2009 what all do you have to do to recharge them? From what I was told you can take them to any welding or fab shop and they can do it for you. It's just refilling them with nitrogen. Quote
WantABanshee Posted December 2, 2009 Report Posted December 2, 2009 if they don't leak why do they need recharged? Quote
SAVAGE420 Posted December 3, 2009 Report Posted December 3, 2009 if they don't leak why do they need recharged? Takes 2 mins to fill them with nitrogen for about $10 per side. It has Nothing to do with the shaft seals and oil, technically. It barely takes anything to fill them. In fact, all the nitrogen would totally be gone by barely touching the valve stem. You could even run oxygen in them BUT, Nitrogen will not heat up and expand like oxygen will, meaning that your suspension will stay much more consistent and not heat up as quick or as bad.. It also will be less likely to leak down, as the nitrogen molecules are larger than oxygen molecules. Nitrogen gas works the same way in your tires as well. The other point is that oxygen is reactive and will corrode the inside of the resevior, where as nitrogen is not and will not. You could use any other dry inert gas Argon, Helium etc. You can not use dry air because dry air is not truly dry, the methods used to extract the moisture do not give a truly dry gas unlike distillation. Just throwing that out there. Snag these fellas, good deal. Quote
quikshee Posted December 3, 2009 Author Report Posted December 3, 2009 Takes 2 mins to fill them with nitrogen for about $10 per side. It has Nothing to do with the shaft seals and oil, technically. It barely takes anything to fill them. In fact, all the nitrogen would totally be gone by barely touching the valve stem. You could even run oxygen in them BUT, Nitrogen will not heat up and expand like oxygen will, meaning that your suspension will stay much more consistent and not heat up as quick or as bad.. It also will be less likely to leak down, as the nitrogen molecules are larger than oxygen molecules. Nitrogen gas works the same way in your tires as well. The other point is that oxygen is reactive and will corrode the inside of the resevior, where as nitrogen is not and will not. You could use any other dry inert gas Argon, Helium etc. You can not use dry air because dry air is not truly dry, the methods used to extract the moisture do not give a truly dry gas unlike distillation. Just throwing that out there. Snag these fellas, good deal. Thanks for laying that out for me savage. Quote
