they are standard mr-16 bulbs and that's what sets the brightness/beam angle, etc. they give you bulbs, but you put whatever you want in there, just like the trailtechs.....just buy new ones when the housings wear out. i run a 20 and a 50, one spot, one flood, but you can pick whatever you want from the hardware store, just keep it to 70 watts total on a stock stator.
well, you really need the spot, imo. you can get 10 degrees, 15, etc. it all depends on what ridding you do. the floods come in handy for tight, technical shit. if you go brighter and narrower on the spot, you can ride faster, but you can see alot better in the technical with a brighter flood, but still see decent on the spot. if you don't get technical, then 2 spots, 1 wider angle, 1 narrower
I like to ride the open areas fast and climb bowls at night but I recently got into riding trails and screwing myself over in treeshots in the middle of the night haha, so for that a spot/flood combo would work well for me? I might have to try that 50/20 you speak of..
