GhostRider Posted November 29, 2009 Report Posted November 29, 2009 hello guys i bought new pads today, and i was trying to install it on the rear brake, removed brake oil hose, removed the 2 bolts that grabs the brake and removed the 2 bolts that holds the pads... removed the old pads ... then i installed the new pads on the rear brake, everything installed good .. my problem is now when i hit the rear brake, its like nothing happend and it moves so fast, its like no oil pressure, i filled it with new brake oil... and i keept hitting the rear brake... still nothing happend .. i dont know what i did wrong to it.. i must installed the pads without removing the brake oil hose right? Quote
bansheekx Posted November 29, 2009 Report Posted November 29, 2009 hello guys i bought new pads today, and i was trying to install it on the rear brake, removed brake oil hose, removed the 2 bolts that grabs the brake and removed the 2 bolts that holds the pads... removed the old pads ... then i installed the new pads on the rear brake, everything installed good .. my problem is now when i hit the rear brake, its like nothing happend and it moves so fast, its like no oil pressure, i filled it with new brake oil... and i keept hitting the rear brake... still nothing happend .. i dont know what i did wrong to it.. i must installed the pads without removing the brake oil hose right? You dont have to remove the brake line to change the pads, just push the caliper piston back and put the pads on. Your going to have to bleed the brakes to get your brakes to work now. Quote
GhostRider Posted November 29, 2009 Author Report Posted November 29, 2009 You dont have to remove the brake line to change the pads, just push the caliper piston back and put the pads on. Your going to have to bleed the brakes to get your brakes to work now. how to do that? Quote
bansheekx Posted November 29, 2009 Report Posted November 29, 2009 how to do that? Fill the resevoir with brake fluid and pump the brake pedal, hold the pedal down and loosen the bleed screw on the caliper. Brake fluid and air should come out of the screw, while still holding the pedal down tighten the screw. Repeat the steps until the pedal becomes firm and dont let the resevoir run out of fluid or you will have to start over. Quote
