prb Posted November 25, 2009 Report Posted November 25, 2009 Does anybody put a thin layer of yamabond around the outside of the crank seals when they install a new crank and seals or just install them dry. Quote
Hilarious Posted November 25, 2009 Report Posted November 25, 2009 Does anybody put a thin layer of yamabond around the outside of the crank seals when they install a new crank and seals or just install them dry. i dont. i usually just run some threebond up to the pockets in the cases where the seals go. I do pack the seals with grease though. Quote
prb Posted November 25, 2009 Author Report Posted November 25, 2009 i dont. i usually just run some threebond up to the pockets in the cases where the seals go. I do pack the seals with grease though. Thanks I also pack all seals with grease just wasn't sure if it would be good to seal around the crank seals. Thanks for your answer. Quote
Koolguyson Posted November 25, 2009 Report Posted November 25, 2009 You should always put sealer around the crank seal. It is good insurance. I also put 1211 on the key, small primary gear, and the waterpump gear because oil can get into your crankcase via the woodruff key. Last thing you want is to take the thing apart if it leaks. It doesn't happen often. But it does happen. Quote
bigboybanshee Posted November 25, 2009 Report Posted November 25, 2009 I do the same as koolguyson. I used to only put it around the crank seal until I had my first leak through the keyway. Oil CAN get past it and it'll blow smoke like a freight train Quote
prb Posted November 25, 2009 Author Report Posted November 25, 2009 I do the same as koolguyson. I used to only put it around the crank seal until I had my first leak through the keyway. Oil CAN get past it and it'll blow smoke like a freight train thanks I will do that. Quote
sleeper06 Posted November 26, 2009 Report Posted November 26, 2009 I have actually seen a woodruff key leak on a pressure test,I go silly with 1211 everywhere,the stuff is amazing Quote
