Crank had a froze bearing on it. Had a machine shop pop off the old bearing and press on the new bearings. Looking over the crank I saw that one rod has ALOT more slop then the other rod. Looked at where the crank presses together so a person could replace the needle bearings and it is not pressed together all the way. How could I press it together more? Think it twisted when the bearing froze?
Thanks guys. Alittle disappointed
stock crank im assuming? itll be cheaper and easier to scrap the whole thing and buy a new or used one. im sure someone here has a used one. PM "NYUK". hes prolly got 10 of them laying around.
if that pin has mooved at all, that part of the crank is done, due to the fact that it has released due to side play. i have a stock crank, that has moved a 1/16" and it is going in the trash as soon as i pull the rods. however, i believe it was the flywheel side that is bad, and the pto side is still good/useable. pm me if you are interested in it.
