Hello, everyone, just got the banshee together, put a new set of carbs on (well used but new to me)
when started the clutch side cylinder just loads with fuel, pipe doesent get hot on that side, the bike will start on just the dead cylinder just loads with fuel and fould the plug..
any ideas? does not matter where u put the airscrew or idle, it wont make a difference...TOR is also deleted
also raw fuel is coming out of the exhaust on that side, it will fire sporatically then nothing at all
compression was 120 on both sides fyi
Edited by vtekthis
Check for a stuck float, a bad needle, and seat above the float, or wrong float height. If you keep running it, without fixing the problem, you'll probably end up hydro locking the motor, and bending the crank, or rod, or both.
It takes fuel, air, and fire to ignite each cylinder. You are getting fuel, so which of the other 2 are you missing? Switch plug wires to see if it is spark. Check pickup gap on both tabs. Should be .012". Air is easy to check eliminate, run without filters.
SP
