crash&burn Posted November 13, 2009 Report Posted November 13, 2009 when riding my banshee threw 1st 2nd and 3rd it runs great powers threw until i go to 4th or 5th it acts likes theres not enough fuel in those gears when it gets close to hitting powerband it like it almost hits a govener or somethin no more acceleration... it became a little herder to stqart now as well..... and while riding it sometimes the throttle will stick in places and will stay stuck untill i hit the kill switch or sometimes tap throttle real quick and it will idle down... i pulled my K&N's off when it idles high to see if the needle is stuck and everything looks normal...... Quote
crustydemon Posted November 14, 2009 Report Posted November 14, 2009 What carbs are you running? Quote
3lue by u Posted November 17, 2009 Report Posted November 17, 2009 My 98 shee is doing the same thing. I have stock carbs on it. I also just got the quad recently s I am kinda new to banshees but not quads or two strokes. Quote
fastbanshee8 Posted November 17, 2009 Report Posted November 17, 2009 If it's idling high, or the revs won't drop, when you let off the throttle, chances are it's lean. It could be a jetting problem, or an air leak. What jets are in the carbs, how many turns out on the air screws, on what slot is the clip on the needles, what's your temp, and elevation? Quote
