Ok I don't know what technical name is but I need the nut that screws down onto
of the lower steering stem bearings the guy at local shop can't find it on yamaha diagrams I believe it's a 30 mm
CLICK HERE
You want Part # 22, bearing holder
Also theres an easy way to lock that bearing holder down. Take a 30mm nut and weld it to a old socket and you have your tool. Just make sure the nut is center on the socket.
Edited by PaddleShee
