RedStrapperRacing Posted October 24, 2009 Report Posted October 24, 2009 (edited) Alright guys my stock carbs keep leaking fuel until I have a puddle under the quad and already checked the obvious -it's not the float bowl screw that is loose. I haven't trouble shot it but think it's probably a stuck float leaving the valve open. Sounds like a good excuse to give the wife LOL - I've been kicking around the idea of getting new carbs for it anyway to up the preformance - any recommendations from fellow Banshee riders would be appreciated. What kind / brand of carbs? What size 28mm, 30mm - 34mm? What type - round slide / flat slide? Riding style - 80% on trails on 20% MX Track Motor is stock bore with 18hrs on original break-in, with T6 Toomeys & stingers, V-Force3 Reeds, K&N dual filters, TORS are removed, motion pro twister throttle installed Edited October 24, 2009 by RedStrapperRacing Quote
#1JUANstunna Posted October 24, 2009 Report Posted October 24, 2009 Savage420 runs a set of 30mm that he really likes and I think Im going to put on mine too. http://www.carbparts.com/index.html# Call them and tell you what you have they are around $200 comes with cable also. Their on eGay too. http://cgi.ebay.com/ebaymotors/30MM-D-slide-Carbs-for-Yamaha-Banshee_W0QQitemZ230391184180QQcmdZViewItemQQptZMotors_ATV_Parts_Accessories?hash=item35a4627b34#ht_500wt_1182 Quote
RedStrapperRacing Posted October 24, 2009 Author Report Posted October 24, 2009 Thanks Boss - I will check these guys out,. Did he have to put larger intake boots on his reed valve? Can't remeber at what size you have to change out the stock one. Quote
00tbanshee Posted October 25, 2009 Report Posted October 25, 2009 pretty sure you will beable to get them on your stock intakes Quote
#1JUANstunna Posted October 25, 2009 Report Posted October 25, 2009 Savage told me that everything will work with the stock intake and airbox Quote
