I took my water pump apart today becuase I plan to replace it with a billet pump either from pro design or mull havent decided yet. When I was spining the water pump I noticed that the shaft of the water pump seemed to spin more in the bearing then the actually bearing spining itslef does that seem normal.
If the bearing is failing, it would cause the shaft to spin in the inner race. They are not a press fit into that bearing. Just pops in.
Brandon
