Lube it up well with the oil you use.
Are both sides of both pistons going you fuss?
both sides are a cunt.... almost like the pin is too big for it ...
can i heat the pin up?
HAHA no, go the other way though, stick them in the freezer for over night and then lube them up and the hole and they should pop right in. Mine whet it pretty snug too, but they went in.
This prob insnt the case with yours, but when I was putting new pistons in mine one of the pistons had a tiny burr where the pin slides through and I couldnt get the pin in, so check for that and file it down if there is one. Just a thought
im freezing the rod now..
Why and how are you freezing the rod? Just stick both wrist pins in the freezer man :headbang:
the freezer?
and the rod wont even slid into the piston... but im being told it will only side in one way...
Yes man, the wrist pins in the freezer for a good while, like 2 hours or so. And they will go in both ways from both sides.
I had to do this on my sled years ago, shit worked.
got it... should fire saturday...
What did you do?
