Hey all, I was wondering if you can give me some information on this issue. It seems to me that there is alot more smoke coming out the left side exhaust. It is also more powerful it seems. When I put my hand behind the exhaust the force of the air is alot stronger then the right side. What can be the cause of this?
Also, is there any references pictures, information on how to get the clutch cable back to its original position and placement after rebuilding the motor.
Any Information will help. Thanks
Do a compression test. If that is fine, switch the plug wires around and see if the problem switches sides. The lack of smoke could also be a lean condition on that cylinder.
Edited by black sunshine
