rubeat Posted October 3, 2009 Report Posted October 3, 2009 Can a crank with a spun rod bearing be rebuilt?I have one that is spun and its pretty bad.Y ou can move it up and down a 1/4 of a inch or more and the rod is all blue. Thanks Quote
AKheathen Posted October 3, 2009 Report Posted October 3, 2009 well, i sure hope the rod bearing has spun....severl times, lol. sarcasm aside, you can buy a rod kit and it comes with the rod, shaft, upper/lower needle roller bearings, and thrust washers. it just all depends on how much you want to spend to rebuild the whole thing. sounds like the rod is probably gouged at the least. you need to mic all the bearings and determin if you can get away with 60-80+labor, or better off new assembly. Quote
