I was trying to put one of these lowering blocks on last night because I thought it would be nice to be able to lower the rear to do a little ice racing this winter but I cant figure out how its suppose to work.It seems to be too tight against the swingarm and I can only get the bolt to go in the hole that would be one step lower than stock, It just seems like the angle is wrong. What did I do wrong and are these even worth messing with?
I had used one for flat track and had the same problems. I ended up clearancing the block a little to get it to fit.
Yep,I was looking at it again and thats what has too be done, theres no other way it'll work.
