I have been installing my new intakes, spacers, reeds, needles, jets, and new carbs over the last few days. I bought the big carb adapters from fast for the stock airbox, but needless to say it wont fit. So i need some filters with outerwears badly! Please help!
I have...
-Stock airbox
-K & N Filter
-EHS Racing airbox lid
-Stock Carbs, with aftermarket TORS removed tops
-DG front bumper
I wont have funds for about a week, and really need these filters with outerwears... I can do trades! Thanks.
I have...
-Stock airbox
-K & N Filter
-DG front bumper
The adapters will work you just have do a few modifications! I had to shorten the 2 tubes on the front of the box! Pods are the way to go !!
Edited by Paul M
Its like impossible to get the front two mounts to pull into the nipples and then get the two bolts in the back....It simply wont fit!
Yes it will work easy. I run spacer and larger carbs also with a box, it moved the box back about 2", and works fine.
Ill show you a pic or 2 when i get home.
Edited by savage420
Ok, all you need to do is cut both the stupid lil nubs off the frame where them dumb plastic wings that stick off the side of the air box connect.
I used a dremal with a lil cut off wheel or you can use a hack saw, takes a min per side. Simple.
Plus you never need them pain in the ass tabs on the front ever again anyways....
Then is will fit in perfect. THEN on the back just get some zip straps and zip strap the plastic part to the mounts on the frame. Ive done this to a few banshees and it works great. I dont like pods as it gets wet here some rides.
Where it mounts to the frame on the back when you go to use the zip straps you might have to slightly bend down them tabs just a cunt hair to make it fit snug.
It fits really nice and don't move around at all....
Here are the pics. Like i said it works great in looks good also.
If you don't understand something just ask me.
http://img268.imageshack.us/img268/4416/airboxinstal007.jpg
http://img97.imageshack.us/img97/8150/airboxinstal005.jpg
http://img97.imageshack.us/img97/9017/airboxinstal006.jpg
Edited by savage420
