Fullthrottle02 Posted September 10, 2009 Report Posted September 10, 2009 Buddy has a 96 that was running fine one day, parked it and now it wont rev up. It will still start, harder than usual though, but wont rev up. There is no TORS, checked ignition coil, wires, harness for loose or bad connections, cdi, carbs, reeds, you name it. I believe it has to be electrical. The only thing that hasn't been checked is the pickup coil on the stator which we will be checking tonight. Has anyone run into this problem, any other ideas on what it could be? Quote
blowit Posted September 10, 2009 Report Posted September 10, 2009 Buddy has a 96 that was running fine one day, parked it and now it wont rev up. It will still start, harder than usual though, but wont rev up. There is no TORS, checked ignition coil, wires, harness for loose or bad connections, cdi, carbs, reeds, you name it. I believe it has to be electrical. The only thing that hasn't been checked is the pickup coil on the stator which we will be checking tonight. Has anyone run into this problem, any other ideas on what it could be? Parking brake switch..... Adjust the parking break on the clutch perch and that should make your problem go away. You can also delete that switch by unplugging it in the harness. Brandon Quote
Fullthrottle02 Posted September 10, 2009 Author Report Posted September 10, 2009 doesnt have parking brake switch, cdi has the 2-4 wire connector not new style. Quote
blowit Posted September 10, 2009 Report Posted September 10, 2009 I missed the 96. Best of luck. Sounds like your on the right track. Brandon Quote
