theoriginal87 Posted September 10, 2009 Report Posted September 10, 2009 iv noticed when im out riding my banshee it seems to lak power in the bottom of first and a few other gears.. it just kinda seems to bog then it gets to a point and then it freakin screams! just wondering if this is normal?? Quote
NickisGod Posted September 10, 2009 Report Posted September 10, 2009 x2 im having the same issue ever since one day i got it wet one day riding Quote
AKheathen Posted September 10, 2009 Report Posted September 10, 2009 clean your carbs out real good, especially the emultion tubes an air jets. (the tube the needle slides in and the little jet/passage in the opening of the filter side of the carb) idles/ starts fine, right? Quote
theoriginal87 Posted September 10, 2009 Author Report Posted September 10, 2009 clean your carbs out real good, especially the emultion tubes an air jets. (the tube the needle slides in and the little jet/passage in the opening of the filter side of the carb) idles/ starts fine, right? it idles just fine and runs great other than that and when i get in the very top of sixth it seems to just kinda sputter and loses power at full throttle in sixth.... but starting it is another story :\... it picks and chooses when it just starts right up and other time my foot is sore from kicking so much... i posted a thread on the starting earlier if u maybe want to look at that.. Quote
swrbansheeboy Posted September 11, 2009 Report Posted September 11, 2009 dumb question but are you running the stock mikuni carbs and if so is the choke crossover tube installed between the carbs? Quote
Darthwall Posted September 11, 2009 Report Posted September 11, 2009 have you done any mods to it without changing the jetting like pipes carbs air filters elavation? Quote
theoriginal87 Posted September 11, 2009 Author Report Posted September 11, 2009 (edited) well the bike has pro circuit pipes and silencers, k&n air filters and a klutch kit but it still has the stock carbs on it... but yea i made sure that the tube was in place this morning and it is. so im still kinda stumped and don t know waht the jetting should be... but when i cleaned the carbs it looked like they were 250's Edited September 11, 2009 by theoriginal87 Quote
AKheathen Posted September 11, 2009 Report Posted September 11, 2009 oh jeeze, 250 is real small for having pods and pro-circuits. what's your elevation and ridding temp? Quote
theoriginal87 Posted September 12, 2009 Author Report Posted September 12, 2009 (edited) oh jeeze, 250 is real small for having pods and pro-circuits. what's your elevation and ridding temp? yeah well i just bought a tors elimination kit and was going to buy a rebuild kit for my carb but wanted to see if i posibly was going to have to change my jetting..... but my elevation is about 4500 above sea lvl.. couldnt tell u what my temps are though... was planning on gettinng a high flow impeller and some other things to just make sure it stays cool nut any idea what my jetting should be? i just bought it not to long ago so im still kinda learning everything :/ Edited September 12, 2009 by theoriginal87 Quote
AKheathen Posted September 12, 2009 Report Posted September 12, 2009 yeah well i just bought a tors elimination kit and was going to buy a rebuild kit for my carb but wanted to see if i posibly was going to have to change my jetting..... but my elevation is about 4500 above sea lvl.. couldnt tell u what my temps are though... was planning on gettinng a high flow impeller and some other things to just make sure it stays cool nut any idea what my jetting should be? i just bought it not to long ago so im still kinda learning everything :/ you run local pump, right? i would start with 330 mains, stock needles in middle clip, and airscrews 1 turn from seated. be prepared to go down as far as 280 on the mains, as that elevation could carry different levels of fuel, and the temps can factor you a few sizes, also. proper plug chops can get you jetted right. Quote
theoriginal87 Posted September 13, 2009 Author Report Posted September 13, 2009 you run local pump, right? i would start with 330 mains, stock needles in middle clip, and airscrews 1 turn from seated. be prepared to go down as far as 280 on the mains, as that elevation could carry different levels of fuel, and the temps can factor you a few sizes, also. proper plug chops can get you jetted right. yeah i run premium gas 32:1 through it right now.... but thanks im just tring to get everything fixed and right before i really ride it to hard.. but im gonna order a rebuild kit for my carbs and some new jets. but today i noticed that i have a boost bottle installed to apparently so i dont know if that would effect it any as well? Quote
AKheathen Posted September 13, 2009 Report Posted September 13, 2009 the boost bottle will effect the pilot a little. more so, the colder it gets. may need to buy some 27.5 pilots. Quote
rubberneck Posted September 13, 2009 Report Posted September 13, 2009 the boost bottle wont affect anything. And at 4500 ft, i think 330s will put you pretty rich, i run 330s at sea level with t5s. I bet you end up in the 300 range or less, not sure because i have not personally jetted procircuits but pretty sure they dont require larger mains than t5s Quote
AKheathen Posted September 13, 2009 Report Posted September 13, 2009 the boost bottle wont affect anything. And at 4500 ft, i think 330s will put you pretty rich, i run 330s at sea level with t5s. I bet you end up in the 300 range or less, not sure because i have not personally jetted procircuits but pretty sure they dont require larger mains than t5s yes it does. @ colder temps anyways. and pro circuis can be pretty fuel hungry. i'm 350asl non-ported. the fuel @ the local station will have fuel which atomises differently for higher elevations, which will bring you up a couple sizes, and the 4500level is one of the tweeners, which can be for 4500+ or 4500- fuel Quote
SonOfSand Posted September 13, 2009 Report Posted September 13, 2009 I ran 280's with the mods below @ 5000 ft, temps as low as 55 degrees. I think you are lean. Quote
