theoriginal87 Posted September 9, 2009 Report Posted September 9, 2009 it seems on my shee when i leave the gas on fo any sorta time it floods itself out and wont start so i have to turn the gas off and kick till she comes to life alittle annoying at times but the main thing is the petcock for the fuel sucks to turn on and off its really stiff and leaks abit. so i was just wondering if there was a rebiuld kit or something or if there were any other solutions out here?? Quote
spurdy Posted September 9, 2009 Report Posted September 9, 2009 it seems on my shee when i leave the gas on fo any sorta time it floods itself out and wont start so i have to turn the gas off and kick till she comes to life alittle annoying at times but the main thing is the petcock for the fuel sucks to turn on and off its really stiff and leaks abit. so i was just wondering if there was a rebiuld kit or something or if there were any other solutions out here?? Replace it with a Pingle petcock. No more flow problems as you upgrade and need more fuel. Easy to change also. SP Quote
dajogejr Posted September 9, 2009 Report Posted September 9, 2009 Hardest (longest) part about changing a fuel valve is draining the gas from the tank. You can cheat, take the tank off, tip it sideways...but you'll have the best luck draining the tank (swish it around and get any debris out while it's off) and using brake clean on a rag to get a clean, dry surface. If you do got with a pingel, don't forget to use teflon tape on the threads of the fuel valve where it goes into the plate. You can usually find a used pingle for 50 to 60 bucks, and a new for 75ish or so. I saw stock fuel valve rebuild kits, however...on ebay for 17 bucks shipped just a week or so ago. Quote
theoriginal87 Posted September 9, 2009 Author Report Posted September 9, 2009 alright thanks that was exactly what i was looking for! Quote
