My jam nut on my front main drive spocket comming off the tranny will not stay tight. ride a mile or two and its ready to fall off.. how the hell do i tighten this thing down? ive wrenched on it over and over agian and still comes loose. the threads on both the nut and the shaft are fine. is this a common problem?
Theres a lock washer that goes behind that nut. Make sure the tab on the washer is bent over part of the nut and it wont come loose.
Similar kind of washer that goes behind the clutch basket nut. :ph34r:
