ok so i bought a cheap ebc clutch kit off ebay and installed it, there were marks on the plates, i just read that maybe those marks are used to line the clutch plates up every 60 degrees, i didn't see any grooves in the plates where they fit into eachother or anything. the new clutch kit didn't come with the rubber to go under the plates do i need to take this apart and line the plates up? if so how do i line them up? and do i need to pull the rubber from inside the plates?
look at the next thread b4 yours man. same exact question. do a lil searhin you can find an answer to almost ne question on this site. its almost all been covered.
nobody gave a clear answer in his thread.... not to mention he said his didn't have marks, but after searching google for 30 minutes i found these
