Minkia38 Posted August 20, 2009 Report Share Posted August 20, 2009 These prices are valid until September 30th, 2009 questions: minkia38@gmail.com please do not PM Frame components J Frame $100.00 (title add $100), A-arm frame, $250 (title add $100), Steering stem $25.00 A-arms / J-arms with brakes, hubs, spindles, and tie rods $300.00 Swingarm $50.00 Axle $100.00 Bearing carrier $60.00 Footpegs $10.00 Nerf Bars / Metal Heel guards $50.00, add $50 for plastic heel guard pieces Rear Hubs $50.00 Rear Sprocket & Hub $15.00 Rear Brake disc & Hub $15.00 Dogbone $10.00 Rear Grab Bar $20.00 Front Bumper Pushbar $50.00 Shifter $10.00 Skid Plate $20 Running Engine $1000.00 Rubber intake boots/Boost $30.00 Reeds and cages $20.00 Carbs and cable $100.00 Airbox (or air filter) $50.00 - $80.00 Kickstarter $50.00 Gas Tank $30.00, $15 for one with bad fenders mounts Pipes $35.00 stock - $300.00 chrome aftermarket motor parts: cylinders $300 crank $175 shift drum, rods, forks $25 gears/tranny $130 cases $150-$200 clutch cover $30 stator cover $ 10 stator & timing plate $80-$100 internal bolts $25 head $15-$35 flywheel $75-$100 Plastic Front & rear Fenders $100 - $300.00 Radiator Plastic $35.00 Gas Tank Plastic $35.00 Seat w/ latch $40-$100.00 Fender brackets $15.00 Electrical CDI Box $60.00 Wiring harness / Loom $30.00 - $60.00 Coil $30.00 Headlights $75.00 on/off switch $25.00 Key w/ plastic housing $35.00 Taillight $20.00 Misc Rear brake setup $125.00 Bolt set $30.00 Rear Shock $75.00 Front shocks $70.00 Front tires & rims $100.00 varies Rear tires and rims $100.00 varies Handlebars & grips $10.00 Clutch lever / perch $10.00 Thumb Throttle assembly $25.00 Radiator & Reservoir $25.00 Radiator and lines - $20 Front brake lines $10.00 Front brake lever/rezzy $15.00 Motor Mounts $10.00 *fullbores not for sale, that my bike! Quote Link to comment Share on other sites More sharing options...
bad 350 shee Posted August 20, 2009 Report Share Posted August 20, 2009 do u have any cpi in frame pipes Quote Link to comment Share on other sites More sharing options...
Minkia38 Posted August 20, 2009 Author Report Share Posted August 20, 2009 do u have any cpi in frame pipes sorry, no cpi pipes, all my aftermarket pipes are up on ebay right now Quote Link to comment Share on other sites More sharing options...
bansheebarnes Posted August 20, 2009 Report Share Posted August 20, 2009 is the grab bar aftermarket or stock? Quote Link to comment Share on other sites More sharing options...
downNdirty Posted August 20, 2009 Report Share Posted August 20, 2009 are these prices shipped? Quote Link to comment Share on other sites More sharing options...
Minkia38 Posted August 20, 2009 Author Report Share Posted August 20, 2009 is the grab bar aftermarket or stock? stock grab bar $20 Quote Link to comment Share on other sites More sharing options...
captainhowdie Posted August 21, 2009 Report Share Posted August 21, 2009 are these prices shipped? i hope so Quote Link to comment Share on other sites More sharing options...
vegas banshee Posted August 21, 2009 Report Share Posted August 21, 2009 got any clarke desert tanks? Quote Link to comment Share on other sites More sharing options...
ELKARACING_SHEE Posted August 21, 2009 Report Share Posted August 21, 2009 ME WANT PAUL TURNER PIPES :smile: Quote Link to comment Share on other sites More sharing options...
zach45 Posted August 21, 2009 Report Share Posted August 21, 2009 (edited) 150 for cases shipped? no chain brake if so send me your paypal.. clutch basket? with the big and little gears? Edited August 21, 2009 by zach45 Quote Link to comment Share on other sites More sharing options...
pipewelder Posted August 22, 2009 Report Share Posted August 22, 2009 I need a left front fender brace. Quote Link to comment Share on other sites More sharing options...
Minkia38 Posted August 22, 2009 Author Report Share Posted August 22, 2009 are these prices shipped? shipping is extra Quote Link to comment Share on other sites More sharing options...
Minkia38 Posted August 22, 2009 Author Report Share Posted August 22, 2009 mint cases with no break is $200 ones with break is $150 add $20 for shipping fender brackets are $10 plus $10 shipping bolt in clutch assembly with 2 gears, backet, boss, plate, springs, and clutch fibers is $140 sorry, no PT pipes sorry, no oversized gas tanks Quote Link to comment Share on other sites More sharing options...
downNdirty Posted August 22, 2009 Report Share Posted August 22, 2009 (edited) shipping is extra i was on ebay and saw a clutch cover for 24.99 (buy it now). which is one of your listings. But here at the HQ you are asking 30. I figured the parts are cheaper here. Specially when you said the prices are valid till sept (something). Edited August 22, 2009 by downNdirty Quote Link to comment Share on other sites More sharing options...
Minkia38 Posted August 22, 2009 Author Report Share Posted August 22, 2009 i was on ebay and saw a clutch cover for 24.99 (buy it now). which is one of your listings. But here at the HQ you are asking 30. I figured the parts are cheaper here. Specially when you said the prices are valid till sept (something). maybe the BUY IT NOW was $30? Quote Link to comment Share on other sites More sharing options...
