These prices are valid until September 30th, 2009
questions: [email protected]
please do not PM
Frame components
J Frame $100.00 (title add $100), A-arm frame, $250 (title add $100),
Steering stem $25.00
A-arms / J-arms with brakes, hubs, spindles, and tie rods $300.00
Swingarm $50.00
Axle $100.00
Bearing carrier $60.00
Footpegs $10.00
Nerf Bars / Metal Heel guards $50.00, add $50 for plastic heel guard pieces
Rear Hubs $50.00
Rear Sprocket & Hub $15.00
Rear Brake disc & Hub $15.00
Dogbone $10.00
Rear Grab Bar $20.00
Front Bumper Pushbar $50.00
Shifter $10.00
Skid Plate $20
Running Engine $1000.00
Rubber intake boots/Boost $30.00
Reeds and cages $20.00
Carbs and cable $100.00
Airbox (or air filter) $50.00 - $80.00
Kickstarter $50.00
Gas Tank $30.00, $15 for one with bad fenders mounts
Pipes $35.00 stock - $300.00 chrome aftermarket
motor parts:
cylinders $300
crank $175
shift drum, rods, forks $25
gears/tranny $130
cases $150-$200
clutch cover $30
stator cover $ 10
stator & timing plate $80-$100
internal bolts $25
head $15-$35
flywheel $75-$100
Plastic
Front & rear Fenders $100 - $300.00
Radiator Plastic $35.00
Gas Tank Plastic $35.00
Seat w/ latch $40-$100.00
Fender brackets $15.00
Electrical
CDI Box $60.00
Wiring harness / Loom $30.00 - $60.00
Coil $30.00
Headlights $75.00
on/off switch $25.00
Key w/ plastic housing $35.00
Taillight $20.00
Misc
Rear brake setup $125.00
Bolt set $30.00
Rear Shock $75.00
Front shocks $70.00
Front tires & rims $100.00 varies
Rear tires and rims $100.00 varies
Handlebars & grips $10.00
Clutch lever / perch $10.00
Thumb Throttle assembly $25.00
Radiator & Reservoir $25.00
Radiator and lines - $20
Front brake lines $10.00
Front brake lever/rezzy $15.00
Motor Mounts $10.00
*fullbores not for sale, that my bike!
  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
150 for cases shipped? no chain brake
if so send me your paypal..
clutch basket? with the big and little gears?
Edited by zach45
mint cases with no break is $200
ones with break is $150
add $20 for shipping
fender brackets are $10 plus $10 shipping
bolt in clutch assembly with 2 gears, backet, boss, plate, springs, and clutch fibers is $140
sorry, no PT pipes
sorry, no oversized gas tanks
shipping is extra
i was on ebay and saw a clutch cover for 24.99 (buy it now). which is one of your listings. But here at the HQ you are asking 30. I figured the parts are cheaper here. Specially when you said the prices are valid till sept (something).
Edited by downNdirty
maybe the BUY IT NOW was $30?
