ELKARACING_SHEE Posted August 17, 2009 Report Posted August 17, 2009 ok guys so we took apart our 98 banshee, to clean the carbs up, but we found em clean, we took the main jets out and cleaned em up, we tighed them up, then we put the banshee back together, and now it wont start, there is gas in both carbs, but it just wont start. we have put seperatly gas into the pistons heads and it started right up, we took the carbs apart again put em back together and the same thing is going on, we changed the plugs same thing, everytime we put gas into the pistons head it starts, but it doesnt start on its own, this thing is eating me alive i dont know what to do anymore study, I was wondering if you guys can help me out, it still has the tors, and this is happening on my bike, ( MY NEW 98 ) Quote
sleeper06 Posted August 17, 2009 Report Posted August 17, 2009 Did you clean the pilot jets out,If you blow air through the pilot circiut you should feel it in the carb throat with your finger,what is your compression?,how do the reeds look? Quote
ELKARACING_SHEE Posted August 17, 2009 Author Report Posted August 17, 2009 Did you clean the pilot jets out,If you blow air through the pilot circiut you should feel it in the carb throat with your finger,what is your compression?,how do the reeds look? no i didnt clean the pilot jets out,i just cleaned the mains, i dont know what the compression is i will check that tommorow, and the reeds look clean, and they are closed Quote
sleeper06 Posted August 17, 2009 Report Posted August 17, 2009 Clean them pilots,thats a must have ciciut for starting your bike,take them out and run a small wire through it to make sure Quote
SAVAGE420 Posted August 17, 2009 Report Posted August 17, 2009 Put your choke tube back on and secure it. :thumbsup: Quote
pr0blumz Posted August 17, 2009 Report Posted August 17, 2009 Put your choke tube back on and secure it. :thumbsup: X2 Quote
