well its a 421 cub and i have water or condensation in the trany oil after one weekend and have replaced the water pump seal and bearing and the o-ring on the pipe and still no change, dam thing still does it, what my qestion is that can a high pressure cap on the radiator cause to much pressure and push it buy the water pump seal? i have a 22 psi cap. i havent tried swithcing it to a stock pressue cap yet but that is next i guess. :blink:
you may try a stock cap first. is your water pump shaft in good shape? no grooves?
You cut the oring when you put the case on. Easy fix. Grease er when ya do it the next time
Couldn't find pressure spec in Clymers, but 22lbs. sounds kind of high. Excess pressure can cause all kinds of problems. A seal designed for say 15lbs might not hold 22. I've seen car radiators bow out on the sides from excess cap pressure. The only benifit from higher pressure is the coolant will boil at a higher temp.
