333bbb333 Posted August 12, 2009 Report Share Posted August 12, 2009 I am just finishing up a rebuild and my clutch is not working properly, I have not started the bike yet but when I engage the clutch and try to roll the bike it is not letting it move, I can see the clutch working and did all the adjustments like the manual said, plus rechecked torques and install and all seems correct. However I did order a new hinson basket from this guy, it came with plates and pads, the pads are in great shape but are wider than the pads that were in there, plus his did not have the rubber rings, so I added the ones from my set up and they fit but it was a tight fit getting the pads and rubber rings on since the new pads are wider, do you think the rubber pads are causing the problem or are they necessary? And could it be that I dont have it full of oil yet and its not letting the plates slip? Quote Link to comment Share on other sites More sharing options...
333bbb333 Posted August 12, 2009 Author Report Share Posted August 12, 2009 Oh and By the way the push rod, cable, bearing, etc all look in good condition. Quote Link to comment Share on other sites More sharing options...
Sandfrk33 Posted August 12, 2009 Report Share Posted August 12, 2009 Take out the rubber cushions. they only fit with stock clutch plates. Quote Link to comment Share on other sites More sharing options...
333bbb333 Posted August 12, 2009 Author Report Share Posted August 12, 2009 Take out the rubber cushions. they only fit with stock clutch plates. Thanks, thats what I was hoping, im going to be doing that tonight as soon as I get off. Quote Link to comment Share on other sites More sharing options...
