hey guys do u guys remember when i said my banshee was proby blown up??? last weekend well tonight i took out the plugs and they are dry i look in the gas tank and there is no gas???? so i am figuring that i ran it out of gas the other nite and i put my fingers over both cylanders anbd they both blow my fingers out of the hole so it has compression what do u guys think????
Last time i looked at my finger it didn't have a compression gauge attached to the end of it lol. :laugh:
Anyways check the comp, if it checks out i say fill the tank and run the shit outa it, thats if your jetting was perfect before hand!!!
:beer:
:beer:
lol but that is a good sign of it not being blown up right?????
Not neccessarily , your compression needs to be over 100 on both cylinders and within a few lbs of each other.
ya but if its below 100 it still will run though im just saying i can get it to run right the way it sounds????
Did you get a number reading when you put your finger over the hole? No. To determine if it's blown up you must do a compression test.
Or take the easier route and put gas in the tank and try and start it. If it takes a bit to start it, your more than likely low on compression. Either way it is a good idea to have a heads up on your compression.
Always start with the easiest things first. :thumbsup:
i totally understand u but i am just meaning blown up as in like the pistons are melted or somting liek that were the thing wont start at all or run i know if the compression is low u should do a top end but i am just wondering liek that
I thought you had said the head bolts were loose and it was making a bad hissing noise or something.
that was the nite i road it home though like i said the next moring i kicked it forever with the choke and then i took the plugs out and they are dry so it aint getting any gas and the tank is empy to i think i ran it out of gas and it has compression
running it out of gas can cause serious problems. I think the loose headbolts and the hissing noise from under the head is telling you something. Have you put gas in it and tried to crank it?
no i didnt but it has compression and is out of gas
but i mean if it was blown it wouldnt have any compression
Just go stick some gas in it and ride already man :ninja:
