Whats the bigest displacement that i can go on the stock engine case? Also what else is going to be needed to build a higher torque engine....i guess some ported cylinders and a head...how would a low-mid pipe work on a larger displacement engine. Sorry for all the questions but im relatively new to the banshee but not to mechanics...lol
Can someone give me some examples of some engine builds and parts needed or som econtacts for engine builders for the banshee.....all my engine builders and parts knowledge involes street/drag cars...lol...Thanks
it might not be where you actually want to go. but you should be able to reach mid/high 500cc`s with some big bore cylinders. you can have the cases cut to fit a larger crank. If you want a lower end power as well, a powervalve cheetah cylinder would help. with a larger displacement, a typical low/mid rated pipe is going to choke your motor. you should talk with a builder and discuss what you might really want and not what you think you want,... which might not actually be what you want,.... or something.
