blackshee03 Posted July 28, 2009 Report Posted July 28, 2009 hey new here, just rebuilt my banshee. ever since i've owned this machiune it seems like the right side is richer an smokes a little more than the left, can i swap the main jets over to see if it makes a difference or should i play with the air screw. after about 1/4 it smokes like the right side. thanks guys Quote
YA*AM*A*HEAD Posted July 29, 2009 Report Posted July 29, 2009 hey new here, just rebuilt my banshee. ever since i've owned this machiune it seems like the right side is richer an smokes a little more than the left, can i swap the main jets over to see if it makes a difference or should i play with the air screw. after about 1/4 it smokes like the right side. thanks guys honestly i dont think the swap will effect it ...if leaner on one side check for air leaks on intake boots and boost bottle tubes ...mabe reeds , i am no pro by no means just a start for you to look into Quote
blackshee03 Posted July 30, 2009 Author Report Posted July 30, 2009 i know for a fact there are no outside forces acting on it ie leaking gaskets or boots. Quote
1996dragshee Posted July 30, 2009 Report Posted July 30, 2009 air/fuel screw and sync your carbs.check your plugs... Quote
