x_doug_x Posted July 25, 2009 Report Posted July 25, 2009 i'm gonna order some new swingarg bearing carrier bearings. i need to know what size to get, anyone know what swingarm this is? Quote
Darthwall Posted July 25, 2009 Report Posted July 25, 2009 more than likely you might need to take the carrier out of the swingarm and measure the bearings to see what you have. but the round carriers I think take the same bearings as long as you dont want to run a different axle like a 40mm drag axle if its not a 40mm its a 35mm center diameter and then measure the out side of the bearings to see what it is I think a company that deals with then can hook you up. but thats a round housing style banshee carrier at least it should be? Quote
x_doug_x Posted August 2, 2009 Author Report Posted August 2, 2009 more than likely you might need to take the carrier out of the swingarm and measure the bearings to see what you have. but the round carriers I think take the same bearings as long as you dont want to run a different axle like a 40mm drag axle if its not a 40mm its a 35mm center diameter and then measure the out side of the bearings to see what it is I think a company that deals with then can hook you up. but thats a round housing style banshee carrier at least it should be? yea it's a round housing, people i have talked to said it's a +2 lonestar swingarm. i just didn't feel like taking it apart and looking for bearings, wanted to get the bearings and do it all at once, i just pulled the front end apart and have to put bearings in up there too. Quote
