SheeBang92 Posted July 22, 2009 Report Posted July 22, 2009 ok when i started the banshee up it started running at about half throttle and the barb slides seem to be in the correct position would a cracked intake do this? and if not what else would do it? Quote
slopoke Posted July 22, 2009 Report Posted July 22, 2009 ok when i started the banshee up it started running at about half throttle and the barb slides seem to be in the correct position would a cracked intake do this? and if not what else would do it? yes, sounds like an air leak Quote
yamahaman244 Posted July 23, 2009 Report Posted July 23, 2009 or bad reed I had the same thing u start it and it would rev pretty high and wouldn't come down here the throttle cable down by the head was like pitch we moved that good as new Quote
