5.0/Banshee Posted June 29, 2009 Report Posted June 29, 2009 I have a 2005 Banshee, It's completly stock with the exception of DMC 916 Exhaust. I ride it about 2 or 3 times a week. It's always fired right up and run perfect with no problems. the other day i lost my my key and my bro-in-law croosed the red and black wires so it would run without the key. it fired up but wouldn't idle and if you rode at a certain rpm it would cut out very often. I found the key about 20 minutes later and he put it back, so it would run off the key. Well now it still has the same problems. Any help would be very appreciated. Quote
shee4speed Posted June 30, 2009 Report Posted June 30, 2009 prob.just got shit in the carbs.Pull them apart and clean them well. Also clean your airfilter and oil properly.Go from there. Oh,try replacing your plugs too.Welcome to the HQ. Quote
5.0/Banshee Posted June 30, 2009 Author Report Posted June 30, 2009 Thanks I've already cleanded and re oiled the air filter, and changed the plugs. So i guess the next thing to do is clean the carbs. Quote
5.0/Banshee Posted June 30, 2009 Author Report Posted June 30, 2009 Ok, is there any tips on cleaning the carbs?, or is it just as simple as pulling them off and spraying carb cleaner though them and putting them back on? Quote
