Misssppelllleddd Posted June 25, 2009 Report Posted June 25, 2009 I have a Dynatek FS Programmable ignition module and I was wondering if you can still put a timing plate on with it. Or would it be irrelevant to have one? Also has anyone tried a programming kit for one of these? The link for the programming kit is here. http://www.dynaonline.com/skins/products/a...ogramming_kits/ And has anyone tried the Dynatek coils? These are about $130 and I wonder if they are worth the money. The link for the coil is here. http://www.dynaonline.com/skins/products/atvs/coil_kits/ Quote
3SGTE Posted June 25, 2009 Report Posted June 25, 2009 http://www.bansheehq.com/forums/index.php?...&hl=dynatek Quote
VegasJeff Posted June 25, 2009 Report Posted June 25, 2009 I have a Dynatek FS Programmable ignition module and I was wondering if you can still put a timing plate on with it. Or would it be irrelevant to have one? Also has anyone tried a programming kit for one of these? The link for the programming kit is here. http://www.dynaonline.com/skins/products/a...ogramming_kits/ And has anyone tried the Dynatek coils? These are about $130 and I wonder if they are worth the money. The link for the coil is here. http://www.dynaonline.com/skins/products/atvs/coil_kits/ When I bought mine from cascade ,they recomended nothing over +4 on the plate and not to use curve 3.thats the advice they gave me. Quote
Snopczynski Posted June 25, 2009 Report Posted June 25, 2009 Last time I was out, I made myself a custom curve that made my bike run awesome. It had a bunch of low advance, and tapered off at the top to retard a bit. Quote
mopar1rules Posted June 25, 2009 Report Posted June 25, 2009 Last time I was out, I made myself a custom curve that made my bike run awesome. It had a bunch of low advance, and tapered off at the top to retard a bit. that's exactly what i want to do....make a curve that has like 4-5 deg on the bottom, then taper to like 2-2.5 deg mid and then back to stock advance on top end. i think that would work great, as you should have the best of both worlds.....great bottom, w/a good top end that will want to over-rev, instead of feeling dull/flat. Quote
Snopczynski Posted June 25, 2009 Report Posted June 25, 2009 that's exactly what i want to do....make a curve that has like 4-5 deg on the bottom, then taper to like 2-2.5 deg mid and then back to stock advance on top end. i think that would work great, as you should have the best of both worlds.....great bottom, w/a good top end that will want to over-rev, instead of feeling dull/flat. Yeah, I made 4 of them on the laptop at the dunes, and the one I put in on curve slot 4 worked really well. Quote
mopar1rules Posted June 25, 2009 Report Posted June 25, 2009 glad to hear it worked out for you snope. now i'm going to have to really start saving up some more $, so i can get a dynatek, and go along w/my plan of my custom curve. you used the dynatek programming software/kit i assume?? Quote
Snopczynski Posted June 26, 2009 Report Posted June 26, 2009 glad to hear it worked out for you snope. now i'm going to have to really start saving up some more $, so i can get a dynatek, and go along w/my plan of my custom curve. you used the dynatek programming software/kit i assume?? Yeah, I have the software and the cable kit and usb adapter. Quote
