blubeast Posted June 25, 2009 Report Posted June 25, 2009 Ok for those that are going to tell me right off the bat to use the search tool. I have and I still can't find what I need, here is the situation. I tore the bike apart in January of 08, I have moved twice sense and haven't had the time till now to sit down and actually work on it. I tried my best to keep everything together and tag everything. The motor when I started the rebuild was bored .40 with mikuni 28mm flat side carbs. I can't for the life of me remember how the gas gets from the tank to the carbs? Also what do I need to replace the t.o.r.s. because i was planning on doing away with this item. Any help would be awesome and I am a complete noob at this so go easy guys.... :cool: Quote
SAVAGE420 Posted June 25, 2009 Report Posted June 25, 2009 (edited) You use FUEL LINE from the tanks petcock to the carbs brass inlets. :ermm: Its gravity fed. Turn the pet cock on when fuel lines are hooked up and gas will flow through the hoses into the carbs. Tors removal >>> http://www.farmandsandtoys.com/partdetail.asp?partid=123 Fuel lines>>> http://www.farmandsandtoys.com/partdetail.asp?partid=352 Give Jeff at F.A.S.T a call and he will get you both those shipped quick and what ever else you need. :beer: Edited June 25, 2009 by savage420 Quote
Rodneya Posted June 25, 2009 Report Posted June 25, 2009 If you have 28mm flat slide carbs you don't have any TORs anymore. It is already gone. Quote
SAVAGE420 Posted June 25, 2009 Report Posted June 25, 2009 If you have 28mm flat slide carbs you don't have any TORs anymore. It is already gone. Good lookin out rod. i read that to fast i guess. Quote
VegasJeff Posted June 25, 2009 Report Posted June 25, 2009 Good lookin out rod. i read that to fast i guess. savage, is that your real pic in your avitar?If so, love the glasses. :biggrin: Quote
blubeast Posted June 26, 2009 Author Report Posted June 26, 2009 I have just upgraded to those, and then had to stop working on it for a while due to moving. I'm new to this so it completely left my mind that i needed the tors eliminator to do it. I'm lame, haha Quote
