gemini Posted June 24, 2009 Report Posted June 24, 2009 If I let my bike sit overnight per say, there is a small puddle of oil underneath it. I'm fairly confident it's not coming from the drain plug. The top of the case is wet and it looks like its coming down through that hole behind the cylinders in the middle of the cases. Any ideas? Thanks. Quote
twoody Posted June 24, 2009 Report Posted June 24, 2009 is it just oil or is it your premix? i would check all your fuel line connections, check your carbs and intake make sure all is tight. when i pull my carbs off i actually see a little bit of premix sitting just on the outside of my intake boots. have you also recently oiled your chain? maybe its splattering ontop and the excess is leaking down. thats the only thing i can think of but maybe someone else has an idea where it coming from. Quote
okbeast Posted June 24, 2009 Report Posted June 24, 2009 It's crying 'cause you never ride it IMO. Quote
VegasJeff Posted June 24, 2009 Report Posted June 24, 2009 It's crying 'cause you never ride it IMO. haha.. :biggrin: Quote
yamahaman244 Posted June 24, 2009 Report Posted June 24, 2009 haha.. :biggrin: Maybe you kicker seal i know mine had that it would leak alittle pit of oil Quote
gemini Posted June 24, 2009 Author Report Posted June 24, 2009 It's crying 'cause you never ride it IMO. prolly true if it were mine. dad's is the one leaking. i think its just oil. i'll check again and report back. thanks for the info. Quote
twoody Posted June 24, 2009 Report Posted June 24, 2009 if it is just oil x2 on the shaft seal, i had to replace mine cause over time it was leaking. but i found out that i needed a new shift shaft, bushing and seal. if its coming from top the only thing i can think of is the clutch actuator on top of case, maybe bad seal. Quote
okbeast Posted June 24, 2009 Report Posted June 24, 2009 Try drainin all the oil out of it then put the plug back in and see. That'd probably tell you whether it's tranny oil or from the premix. There might be an extra shift shaft seal out there, not sure. Quote
AKheathen Posted June 24, 2009 Report Posted June 24, 2009 is it just oil or is it your premix? i would check all your fuel line connections, check your carbs and intake make sure all is tight. when i pull my carbs off i actually see a little bit of premix sitting just on the outside of my intake boots. have you also recently oiled your chain? maybe its splattering ontop and the excess is leaking down. thats the only thing i can think of but maybe someone else has an idea where it coming from. pry your intakes around and look for the crack where oil is coming through. a little cracking is normal, but once there is premix creeping, it's an airleak. if it's coming from the bore that seals on the carb, use some sandpaper, or scotch brite to seal it. if the premix can get to the outside of the intakes, then air can get in. i've had both leaks before. gemini- has it thrown a chain before? pressurewash the engine, and throw something dry and fine, like cornstartch, or something that will rinse off easy. kinda like "rool 'er in flower to find the wet spot" you might wanna run it for a couple seconds after you wash it. do you have a skidplate? Quote
POORBOY350 Posted June 24, 2009 Report Posted June 24, 2009 prolly true if it were mine. dad's is the one leaking. i think its just oil. i'll check again and report back. thanks for the info. mine was the drain plug just put some cylicone on it. but i snugged all my bolts back up they seem to vibrate loose pretty easy. mine leaks pretty damn bad from the shifter to. i'd just try tightenin all your bolts up or another idea would be to clean the shit out of it ride it for a min and see if you can spot where its comin from. funny enough dust and dirt helps you see oil leaks and stuff lol. if mines cryin its cause i aint got the money to give her the attention she deserves lol. Quote
AKheathen Posted June 24, 2009 Report Posted June 24, 2009 mine was the drain plug just put some cylicone on it. but i snugged all my bolts back up they seem to vibrate loose pretty easy. mine leaks pretty damn bad from the shifter to. i'd just try tightenin all your bolts up or another idea would be to clean the shit out of it ride it for a min and see if you can spot where its comin from. funny enough dust and dirt helps you see oil leaks and stuff lol. if mines cryin its cause i aint got the money to give her the attention she deserves lol. don't forget that the drain plug uses a replaceable copper washer to seal it Quote
yamahaman244 Posted June 24, 2009 Report Posted June 24, 2009 don't forget that the drain plug uses a replaceable copper washer to seal it ya mine from the kicker seal leak some oil not to much though Quote
