kpennepacker Posted June 20, 2009 Report Posted June 20, 2009 I just bought a banshee with no spark. Couldn't pass it up. Guy said it had a new stator on and a used CDI. I tested the stator and the resistance was good. I grab a test lite and I'm getting power form the stator to the CDI. When I tested the wires on the key switch (red with black) and the on/off switch (black with white) I,m getting juice when I turn the motor over. The key switch I wired to the ground and the on/off switch removed and I just cut the wire. I still get no power to the orange coil wire. I need help. What else can I try. Where do I look. When I search the internet and I found this site http://www.dfn.com/benkaren/elecfaq.html. I eliminated everything on my wiring harness just as he said to. The tors, lights are high beam only and the key and on/off switch. Any info would help. please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Quote
Larry's Shee Posted June 21, 2009 Report Posted June 21, 2009 My son recently got a cheep shee. Had spark, but only fired on one cyl. Pulled flywheel, cleaned all poles on stator, wiped out flywheel, cleaned timing tits on outside of flywheel, gapped pickup. Hope this helps. Quote
fastrthnu Posted June 21, 2009 Report Posted June 21, 2009 yea, check the pick up gap, and test the coil. Quote
robert0762 Posted June 21, 2009 Report Posted June 21, 2009 Bought my shee with no spark . All it was was the pickup coil too far Quote
sleeper06 Posted June 21, 2009 Report Posted June 21, 2009 Do you have another cdi to swap out this way you can clear your head of that? Quote
POORBOY350 Posted June 21, 2009 Report Posted June 21, 2009 if it has the TORS box on it its a lil black box under the gas tank on the left side of the frame try plugging or unpplugging it thats caused my cousins bike not to run. Quote
kpennepacker Posted June 21, 2009 Author Report Posted June 21, 2009 I put the gap on the pick up coil at .015. with the test lite i get power from the coil. It's like the CDi is holding it out. I getting power to the CDi and to the kill switchs just no to the coil. I'm the only one with a banshee, all my friends are four stokes, so I don't have another CDI. Quote
