speedman8903 Posted June 17, 2009 Report Posted June 17, 2009 i just got a 04 banshee, i took it to a shop and they checked it and told me evrything is stock except that it has wiseco pistons, and it has cpi pipes, now i do a lot of trail riding and some times theres a straight away or 2, i wanna port and polish the enigine big enough that i can still run 93 octane and go f'n fast, but still ride the trails, i want to get new reeds 2, wut should i get done to her?? i would like advice from the experts from the hq, thanxz chris aka speedman Quote
LiftdT4R Posted June 19, 2009 Report Posted June 19, 2009 Best bet for trail would be to ditch those CPIs and go with a trail pipe. The cpis will make a lot of power higher in the revs. Fmfs are a dime a dozen on flea bay, and are an awesome cheap trail pipe. There are mor expensive choices too. As far as porting, basically every builder does a trail/MX port, find a good builder and give em a call. Hope this helps. Quote
TurningRPMS Posted June 23, 2009 Report Posted June 23, 2009 Okay didth those spis, unless there inframe pipes 1. go with a trail port 2. VF3 reeds will work 3. K&N air filter for stock box 4. Cool head wiht 20 cc domes 5. +4 timing 6. bigger carbs 7. Get teh crank trued/ welded while your at it. That shoudl get your biek plenty fast enough. probaly a little too fast for alot fo trail use. Quote
Wildcardracing Posted June 23, 2009 Report Posted June 23, 2009 Chris, A lot will depend on how open or how tight/technical the trails you ride are. CPI's have a bad rap for being a top end only pipe, but with the right porting they can have a very strong but smooth midrange power curve. Your choice of supporting mods (domes or head mods) will depend on your altitude and fuel you plan to run. Tell us a little more about the trails you ride and what you want out of your engine and we can better help you to make a plan. -Brandon Quote
