just testing the waters to see whats out there. i have a stock cylinder and stroke, triple drag ported w/worm holes. crank trued and welded, cases port matched, lock up, newer clutch and pancake bearing, ran on alky, advanced timing, 17cc domes, 65.5 prolites, coolhead, 2-5 n/down over ride. frame is a non titled 92 stock frame and some rear fiberglass. motor has maybe 10 passes at most and no more then 5 gallons of alky through it. motor runs strong just looking to compete against some of the bigger bikes. i dont have dyno numbers or times on it as we dont have a timed track here or a dyno nearby sorry. Port work done by insane racing. RJ and Joey on the site has seen the bike run.
will not include pipes, reeds, carbs, side covers, or wiring.
would like to see if i could get a 4,7, or 10mm drag ported motor. does not have to have side covers or all the stuff that im not including. but i do want it to have a lock up, and override in it already. i would prefer no stock cylinders but would be an option. prefering cub, cheetah dm, t rex.
i have never shipped a frame before but im sure we can figure it out. lets see whats out there.
if you want pictures of the motor let me know and i will send them over via email. the motor is still in the bike.
