jean-gui-rubber-boots Posted June 13, 2009 Report Share Posted June 13, 2009 Ok, well I wanted to know is there any advantage to getting one year of banshee over the other? Like here is an example: trx450r's 2005's have way more potencial hp wise since there stroke is longer so it will have much more torque, then if you mode the 2005's out they have a stronger tranny so it can take it but stock they have the least power. When the 2006's have a weaker tranny but much more hp stock. Thanks Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted June 13, 2009 Report Share Posted June 13, 2009 This has been covered a lot. Not much changed. 87 - 90 had J-arms 02 and up have a brake light there were different styles of electrical connectors over the years Early Banshees had a different rear wheel pattern 4 on 156 if I remember right, this was the same pattern as the front. Quote Link to comment Share on other sites More sharing options...
jean-gui-rubber-boots Posted June 13, 2009 Author Report Share Posted June 13, 2009 This has been covered a lot. Not much changed. 87 - 90 had J-arms 02 and up have a brake light there were different styles of electrical connectors over the years Early Banshees had a different rear wheel pattern 4 on 156 if I remember right, this was the same pattern as the front. What is the up and down side to j arms and the diffrent rear wheel patterns? Thanks Quote Link to comment Share on other sites More sharing options...
gst_r Posted June 13, 2009 Report Share Posted June 13, 2009 the rear pattern was present on banshees from 89-90 it was 4x156.....4x115 is on 87-88 and 91-06 Quote Link to comment Share on other sites More sharing options...
