I guess my question should be do you know where i can find the part #? :blush:
You can get them from www.carbparts.com or pats small engine.
What pipes are you guys running?
Pro-circuits
Alright thanks, btw, where did you get your eek? I called cascade and they did not know what the eej or eek needles were, I think they need a part # to order it. Sudco and carb parts have them I believe but dont you have to have a minimum of like 50$ or $100?
It came with the carb from Trinity.
Accidently deleted my sig trying to update it. :down:
Edited by Misssppelllleddd
Its probably a CGL needle. You need to have an eek or eej needle. The CGL is for a twin carb setup.
I got a 2 into 1 intake on my bike, 35mm airstryker with airbox/prodesign filter. I think I need one of these needles but im not sure which one, what is the difference between the eek and eej needle?
so, is the eej needle leaner than the eek??
Whats the chart say? If your going to tune this carb, you have got to somewhat be able to at least read a needle chart so you know what changes will do what. The answer is right there on the chart.
eej is a richer from idle to 1/2 throttle
thanks man, thats the answer I was looking for.
