Tf705 Posted June 9, 2009 Report Posted June 9, 2009 (edited) what size dome should i run. i have a hjr drag port, cpi inframes, 35pwk, timing set at +6. im going to run straight 110 mixed around 40:1. should i go with 18 or 17cc domes? just trying to get everything out of it. also from michigan. pretty sure its sea level. Edited June 9, 2009 by Tf705 Quote
RadarRacing Posted June 9, 2009 Report Posted June 9, 2009 Do what kevin says will run best with that setup. I think if you don't have a welded crank the 17s are a bit much. Quote
Tf705 Posted June 10, 2009 Author Report Posted June 10, 2009 my crank is welded. kevin reccomended 18's but i dont think that is taking full potential of 110 gas. but maybe it is? Quote
tundish2800 Posted June 10, 2009 Report Posted June 10, 2009 I have some 17s if you want them pm me Quote
banshee_terror_ Posted June 12, 2009 Report Posted June 12, 2009 I have some 17s if you want them pm me x2 Quote
TeamRealtreeHD Posted June 12, 2009 Report Posted June 12, 2009 Run 17cc domes with that setup... it will tear it up Especially if you are running straight 110. I had the same setup, although I had the hillshooter port job and ran my timing at +5 You will love it... Quote
potpye Posted June 17, 2009 Report Posted June 17, 2009 If you run 17's run VP C12, I had 16's and swapped them out to 18's what a difference the 18's let the motor rev more up top. BTW C12 has 108 motor octane it is more consistent than most fuels. Quote
