bamaboybv Posted June 3, 2009 Report Posted June 3, 2009 What would be better for overall open filed trail/ ohv road riding? An aftermarket Hot Rods crank with c.k. 121 bearings (not sure about the c.k. numbers) Or a stock crank that has been trued and welded Quote
278 Posted June 3, 2009 Report Posted June 3, 2009 The stock one will do just fine, dont waste your money on an aftermarket crank. Quote
bamaboybv Posted June 3, 2009 Author Report Posted June 3, 2009 The stock one will do just fine, dont waste your money on an aftermarket crank. Thank you..that was much needed! Quote
jbooker82 Posted June 5, 2009 Report Posted June 5, 2009 Waste your money on a Hot Rod's 4 mill Long rod crank instead. It is well worth it as long as you get it ported to match the extra stroke. josh Quote
