mrbigsacks Posted May 31, 2009 Report Posted May 31, 2009 was out riding yesterday and shee died. started pissin fuel out overflow when it's kicked. have gone through bike several times especially the carbs. seems that spark is there then gone.starting to think coil or wires and floats adjusted to high. only dies when riding in WOT if I take it easy it's fine. only floods after getting on it. guy who set carbs said he set it to run little rich could that cause it to flood at WOT. any info would be great thanks Quote
AKheathen Posted May 31, 2009 Report Posted May 31, 2009 i ould say re-check the float heights. if it's done it since he tuned it, then that's probably the problem. after the floats are fixed, then re-jet Quote
mrbigsacks Posted May 31, 2009 Author Report Posted May 31, 2009 i ould say re-check the float heights. if it's done it since he tuned it, then that's probably the problem. after the floats are fixed, then re-jet i"ll give it a shot see what happens thanks Quote
