Ineedmoney Posted May 28, 2009 Report Posted May 28, 2009 Okay so i aquired a new set of pipes with alot of rust on them. they are fmf fattys, they are still a whole abd have no bare spots. they just hav erust on the,. how can i remove it or wht can i do it with. Quote
NickisGod Posted May 28, 2009 Report Posted May 28, 2009 heres wat i did for my ptrs first was them as best as u can with a degreaser of your choice make sure u can eat off them. then take sos pads and make sure u have enough water to reduce the pads friction and work on the rust areas then take a steel and chrome specific polisher/rust remover and let it soak in, and then wipe away by this step you should be almost 95% done and it requires attention to detail to cover up them missed spots hope this helps Quote
ny98banshee350 Posted May 29, 2009 Report Posted May 29, 2009 steel wool works great for chrome pipes Quote
Keyser Soze Posted May 29, 2009 Report Posted May 29, 2009 Save your money. Forget elbow greese, remove all the rust from your pipes. http://www.vintagebmx.com/community/index....owtopic=4004702 Quote
miami's_candy_banshee144 Posted May 29, 2009 Report Posted May 29, 2009 how do you get blood off your pipe? lmfao. yes i burned myself pretty good i know Quote
Ineedmoney Posted May 29, 2009 Author Report Posted May 29, 2009 So basically when i get this acid shit and stuff. I fill up my tub wiht it and just put my pipes in there and let them soak for 12-36 hours. HOw will i get the insides dry besides lettign them dry for a couple days. Has anyone else ever used this stuff on pipes. jw. Quote
Keyser Soze Posted May 29, 2009 Report Posted May 29, 2009 Just worry about the outside. I let mine set out of the soak for about twenty minutes. This shits not super flammable so you will be ok. Just make sure you dont soak your packing in your silencers if you do your silencers to. I wouldnt use a bathtub or anything like that either. I used a tubblerware storage bin. Quote
T_Shee Posted May 30, 2009 Report Posted May 30, 2009 how do you get blood off your pipe? lmfao. yes i burned myself pretty good i know ill let you know when i find out. im still trying to get a layer of my wifes knee skin off my t5. i cought hell for that one.....she now has part of the T branded on her tho. Quote
run Posted May 30, 2009 Report Posted May 30, 2009 ill let you know when i find out. im still trying to get a layer of my wifes knee skin off my t5. i cought hell for that one.....she now has part of the T branded on her tho. I saw it, and it's a quality T burn. Quote
TwistedSheeRida Posted May 30, 2009 Report Posted May 30, 2009 spray clr on them let sit then wipe off. i used a scotch brite pad but you dont really need it. $5 clr at wal mart Quote
fastbanshee8 Posted May 30, 2009 Report Posted May 30, 2009 Use this stuff. http://www.homedepot.com/webapp/wcs/stores...uctId=100665892 Just spray it on, and the rust runs off. It's easy, and safe to use. Quote
