xjamesd93 Posted May 27, 2009 Report Share Posted May 27, 2009 (edited) So after a little research i have decide to go with Cheetah Cub 4mm stroker cylinder with Wiseco 68mm pro lite stroker pistons and 4mm stroker crank with a billet cool head that allows standard or bb domes...what size domes should i use? what size carbs? i am roughly 900ft above sea level, and i can run 91 or 93 pump, or mix with airplane fuel, or run straight airplane fuel...the bike will only be used for 300ft drags on dirt....and also do i need big bore drag pipes?? sorry about all these questions but im new with dragging...thanks, any help would be appreciated!! Cheetah Cub Kit cool head Stroker crank Edited May 27, 2009 by xjamesd93 Quote Link to comment Share on other sites More sharing options...
J-Madd Posted May 27, 2009 Report Share Posted May 27, 2009 Why not run alcohol?? I'd say 20 cc domes, 39 mm pwks with billet bowls. Don't mess with a fuel pump for 300 ft. Most run small bore pipes on that engine. Don't forget override, lockup, etc. Quote Link to comment Share on other sites More sharing options...
xjamesd93 Posted May 27, 2009 Author Report Share Posted May 27, 2009 Why not run alcohol?? I'd say 20 cc domes, 39 mm pwks with billet bowls. Don't mess with a fuel pump for 300 ft. Most run small bore pipes on that engine. Don't forget override, lockup, etc. i could run alcohol...where do i get it?? what would i need if i did run alky and override is a override tranny...right? and what is a lockup?? and what is etc?? haha, sorry about the dumb questions, but i am clueless on drag racing...never done it Quote Link to comment Share on other sites More sharing options...
J-Madd Posted May 31, 2009 Report Share Posted May 31, 2009 i could run alcohol...where do i get it?? what would i need if i did run alky and override is a override tranny...right? and what is a lockup?? and what is etc?? haha, sorry about the dumb questions, but i am clueless on drag racing...never done it You may need to run your stock Banshee (if you have one) for a while before you start to build a drag racer until you get used to it. Honestly, I'd buy a turn-key 300ft bike right now before I'd build one. Everything is going cheap. Quote Link to comment Share on other sites More sharing options...
xjamesd93 Posted May 31, 2009 Author Report Share Posted May 31, 2009 yea my banshee is just piped and strutted, and i am going to run it in a couple like it is, but its not fast enough in 300ft...but i would like to buy a built 300ft bike for the right price Quote Link to comment Share on other sites More sharing options...
