gst_r Posted May 27, 2009 Report Posted May 27, 2009 Hi, well after many solutions my friend cannot find what the hell is going wrong with his banshee.....it is a 4mm on gas.....it is weird....example if he closes the petcock......the bike runs fine until the carbs runs out of fuel.......but with the petcock open the bike just bogs....like a rich condition but...the bike was just running great.....so he pulled away the carbs, intakes and vforce....he found that 2 petals...one of each side have small chips....but are only like 4 or 5 on each petal.....can be this his trouble??? he is running stock carbs.... Quote
AKheathen Posted May 27, 2009 Report Posted May 27, 2009 Hi, well after many solutions my friend cannot find what the hell is going wrong with his banshee.....it is a 4mm on gas.....it is weird....example if he closes the petcock......the bike runs fine until the carbs runs out of fuel.......but with the petcock open the bike just bogs....like a rich condition but...the bike was just running great.....so he pulled away the carbs, intakes and vforce....he found that 2 petals...one of each side have small chips....but are only like 4 or 5 on each petal.....can be this his trouble??? he is running stock carbs.... uhh, yah. when it's in idle, the slides act as a stop for the leaking pressure, but when you open the throttle, it alows the pulse out, basically loosing compression. how big are the chips? can you see why they chipped? Quote
blowit Posted May 27, 2009 Report Posted May 27, 2009 When the reeds leak, this allows a "double dipping" situation in where the air fuel mixture is rejected back through the reeds, into the carbs and is charged with more fuel. This over richens the mixture. Very important to have the reed pedals sealing properly. B Quote
gst_r Posted May 27, 2009 Author Report Posted May 27, 2009 When the reeds leak, this allows a "double dipping" situation in where the air fuel mixture is rejected back through the reeds, into the carbs and is charged with more fuel. This over richens the mixture. Very important to have the reed pedals sealing properly. B thanks guys i guess we will try this afternoon to put another reeds....and see how it performs... Quote
gst_r Posted May 28, 2009 Author Report Posted May 28, 2009 well, we don't changed the reeds since my friend is little bit skeptical that with little chips causes the bike to bog, the compression was tested and 140 on each cylinder...i guess we are going to try the reeds and check the stator...any other advice? thanks Quote
AKheathen Posted May 28, 2009 Report Posted May 28, 2009 double check the float heights and choke o-ring Quote
gst_r Posted June 11, 2009 Author Report Posted June 11, 2009 Well the bike of my friend still on the same.....first just seems to be rich.....check compression, change carbs to PJ 34 methanol, changed CDI, Wiring, Spark Plugs, took off the stator and checked nothing wrong......right cylinder was dead, he took it up and nothing wrong, good piston, good rings, any trouble, after it was assembled again......now the left cylinder is the one that is going dead...what do you thinks guys could be the trouble??... Quote
uwenr Posted June 12, 2009 Report Posted June 12, 2009 Well the bike of my friend still on the same.....first just seems to be rich.....check compression, change carbs to PJ 34 methanol, changed CDI, Wiring, Spark Plugs, took off the stator and checked nothing wrong......right cylinder was dead, he took it up and nothing wrong, good piston, good rings, any trouble, after it was assembled again......now the left cylinder is the one that is going dead...what do you thinks guys could be the trouble??... I had the same problem, its the stator. Some stock stators will not fire alky, and will run fine on gas. Try using a stator off a bike you know fires the alky. Quote
